跳转到主内容
Hoover WindTunnel 2 Rewind Belt and Roller Brush Replacement
你所需要的
  1. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: 步骤 1 中的图像 1,2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement, Belt and Roller Brush: 步骤 1 中的图像 2,2
    • Remove the four 20 mm Phillips #1 head screws holding the top cover on.
    • Lift off the cover.
  2. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: 步骤 2 中的图像 1,1
    • Grab on both ends of the roller brush, lifting it and the attached belt clear of the housing.
  3. Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: 步骤 3 中的图像 1,2 Hoover WindTunnel 2 Rewind Belt and Roller Brush  Replacement: 步骤 3 中的图像 2,2
    • Reinstall belt and roller making sure that the white text is facing outwards on the belt.
    • Placing the roller brush in its guides will put some tension on the belt after the roller is in place spin it with your hand a couple times to ensure that it spins freely.
结论
2等其他人完成本指南。
团队
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G4
5 名成员
创作了10篇指南
一条评论
Thank you, made it easy peasy!
J Colee - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 102
总计 8,604
