简介
This guide is intended to show you how to unclog the pipes of your vacuum. You may need equipment such as pipe cleaners, brushes, or sticks to remove the blockages. You need to begin this with the vacuum unplugged.
工具
配件
无需配件。
  1. Press the silver tab on the bottom of the vacuum.
    • Press the silver tab on the bottom of the vacuum.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. To remove hose, rotate pipe counterclockwise  and pull down. Remove hose from vacuum completely by  sliding  piping through bottom housing. Remove hose from vacuum completely by  sliding  piping through bottom housing.
    • To remove hose, rotate pipe counterclockwise and pull down.
    • Remove hose from vacuum completely by sliding piping through bottom housing.
  4. Remove any clogs from the pipe using a long dull object.
    • Remove any clogs from the pipe using a long dull object.
    • Make sure to check the pipe connectors for clogs too!
结论
另外一个人完成了本指南。
Sophia Stockburger
于2018年01月22日注册
530 信誉积分
创作了5篇指南
团队
Cal Poly, Team S11-G2, Banghart Winter 2018 Cal Poly, Team S11-G2, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G2
5 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 13
过去的30天: 55
总计 520
