简介
This guide is intended to help you replace the brush roll on your vacuum. Please see the troubleshooting guide to determine if this needs replacement. Begin this step with the vacuum unplugged, and laying on the floor with the bottom facing towards you.
你所需要的
Push the red release lever to the right.
Turn the red switch counterclockwise.
Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
3条评论
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
