跳转到主内容
Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement
你所需要的
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: 步骤 1 中的图像 1,3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: 步骤 1 中的图像 2,3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: 步骤 1 中的图像 3,3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: 步骤 2 中的图像 1,1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
结论
团队
Cal Poly, Team S11-G2, Banghart Winter 2018 Cal Poly, Team S11-G2, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G2
5 名成员
创作了9篇指南
3条评论
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - 回复
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 18
总计 992
