跳转到主内容
Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement
你所需要的
  1. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: 步骤 1 中的图像 1,2 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: 步骤 1 中的图像 2,2
    • Place the vacuum on its back.
    • On the bottom right side, push the red lever to the left.
    • Remove the plastic cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 2 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 2 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 2 中的图像 3,3
    • Grab the red switch under the brush and push left.
    • Then remove the plastic base plate.
  3. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 3 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 3 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
  4. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 4 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 4 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 4 中的图像 3,3
    • Remove the two screws on the left side of the brush.
  5. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 5 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 5 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 步骤 5 中的图像 3,3
    • Pull the clear plastic away from the head of the vacuum.
    • Slide the belt off the metal rod with your finger.
    • Pull the brush free.
  6. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Vacuum Belt: 步骤 6 中的图像 1,1
    • Removal of the brush will also remove the belt.
结论
Erik Ingels
于01/18/18注册
193 声望
创作了2篇指南
团队
Cal Poly, Team S12-G4, Banghart Winter 2018 Cal Poly, Team S12-G4, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G4
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 785
