跳转到主内容
Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement
你所需要的
  1. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement, Height Adjustment Wheels: 步骤 1 中的图像 1,2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement, Height Adjustment Wheels: 步骤 1 中的图像 2,2
    • Place the vacuum on its back.
    • Push the red switch to the left.
    • The black cover will then pop out. Remove the cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 2 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 2 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 2 中的图像 3,3
    • Locate the red switch near the head of the vacuum.
    • Push the switch left.
    • This will pop out the plastic base plate. Remove the plate from the vacuum.
  3. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 3 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 3 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the screws from the right side of the white plastic frame.
  4. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 4 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 4 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 4 中的图像 3,3
    • Remove screws from the left side of the white plastic frame.
  5. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 5 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 5 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 5 中的图像 3,3
    • Pull the white plastic frame away from the vacuum.
    • Slide the vacuum belt off the metal rod.
    • Pull the brush off the vacuum.
  6. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 6 中的图像 1,2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 6 中的图像 2,2
    • Remove the screws at the bottom of the white frame near the roller.
  7. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 7 中的图像 1,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 7 中的图像 2,3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 步骤 7 中的图像 3,3
    • Pop off the right side of the white frame.
    • Pull down the blue hinge and roller.
    • Pull free the roller from the vacuum.
结论
Nathan Yung
于01/18/18注册
241 声望
创作了2篇指南
团队
Cal Poly, Team S12-G4, Banghart Winter 2018 Cal Poly, Team S12-G4, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G4
5 名成员
创作了9篇指南
2条评论
HOOVER 30310 brush roller stops when the handle is released for vacuuming. Begins again when handle raised and locked into upright position.
David Blair - 回复
Hoover wind tunnel three pet quick pass. Roller spins in an upright position (locked handle). Foot pedal tensioner and off works, but will not stay in off position.
Kirk Teichert - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 39
总计 2,297
