跳转到主内容
Hoover Power Path Pro Advanced Suction Motor Replacement
你所需要的
  1. Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: 步骤 1 中的图像 1,2 Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: 步骤 1 中的图像 2,2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
  2. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 2 中的图像 1,2 Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 2 中的图像 2,2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 3 中的图像 1,1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
  4. Hoover Power Path Pro Advanced Suction Motor Replacement, Belt: 步骤 4 中的图像 1,1
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
  5. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 5 中的图像 1,2 Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 5 中的图像 2,2
    • Pull the red handle shown to remove the front suction unit from the cleaner.
  6. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 6 中的图像 1,1
    • Unscrew the Phillips #2 screw at the bottom of the hose.
  7. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 7 中的图像 1,2 Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 7 中的图像 2,2
    • Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
    • Repeat the above step for the "On/Off" button.
    • When pulling the handle release button, make sure the top of the cleaner does not fall.
  8. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 8 中的图像 1,1
    • Gently grab the belt and pry it off from the rollers.
  9. Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: 步骤 9 中的图像 1,2 Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: 步骤 9 中的图像 2,2
    • Unscrew two screws using Phillips #2 screwdriver.
    • Detach grey piece from vacuum.
  10. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 10 中的图像 1,2 Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 10 中的图像 2,2
    • Unscrew four screws using a Phillips 2 screwdriver.
  11. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 11 中的图像 1,1
    • Pull out of base of vacuum.
  12. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 12 中的图像 1,1
    • Flip vacuum over and unscrew three screws with a Phillips #2 screwdriver.
  13. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 13 中的图像 1,1
    • Unscrew two screws with Phillips #2 screwdriver.
  14. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 14 中的图像 1,1
    • Detach motor and unscrew two screws with a Phillips #2 screwdriver.
  15. Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 15 中的图像 1,2 Hoover Power Path Pro Advanced Suction Motor Replacement: 步骤 15 中的图像 2,2
    • Pull the bottom section off.
    • Pull the cap off.
结论
4等其他人完成本指南。
团队
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G5
5 名成员
创作了15篇指南
1指南评论
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
Billy H. Deal Jr - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 2,584
