跳转到主内容
简介
The power switch allows the Hoover Power Path Pro Advanced to turn on with the press of the power button. A defective power switch will not allow the user to control the on and off state of the device and needs to be replaced.
配件
没有特定配件。
  1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,1
    • Remove the lower brushroll from the bottom of the cleaner.
  2. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 2 中的图像 1,1
    • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
  3. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 3 中的图像 1,2 Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 3 中的图像 2,2
    • Pull the red handle to remove the front suction unit from the cleaner.
  4. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 4 中的图像 1,1
    • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
  5. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 5 中的图像 1,2 Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 5 中的图像 2,2
    • Push down on the handle release button. Lift the edge of top cover connected to this button.
    • Repeat the above step for the "On/Off" button.
    • Pull entire top cover off.
    • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
  6. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 6 中的图像 1,1
    • Remove the "On/Off" cap by pulling it upwards with caution.
  7. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 7 中的图像 1,1
    • Use a long #2 Philips head to remove the two screws from the arched grey piece.
  8. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 8 中的图像 1,2 Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 8 中的图像 2,2
    • Pull out the red power the red power switch.
结论
4等其他人完成本指南。
Jose Andres Gonzalez Valdes
于2018年01月22日注册
682 声望
创作了5篇指南
团队
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G5
5 名成员
创作了15篇指南
3条评论
What is the part number?
martahayner - 回复
Thanks so much!!
debmccrimm - 回复
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 44
总计 2,658
