跳转到主内容
Hoover Power Path Pro Advanced Power Switch Replacement
你所需要的
  1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: 步骤 1 中的图像 1,1
    • Remove the lower brushroll from the bottom of the cleaner.
  2. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 2 中的图像 1,1
    • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
  3. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 3 中的图像 1,2 Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 3 中的图像 2,2
    • Pull the red handle to remove the front suction unit from the cleaner.
  4. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 4 中的图像 1,1
    • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
  5. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 5 中的图像 1,2 Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 5 中的图像 2,2
    • Push down on the handle release button. Lift the edge of top cover connected to this button.
    • Repeat the above step for the "On/Off" button.
    • Pull entire top cover off.
    • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
  6. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 6 中的图像 1,1
    • Remove the "On/Off" cap by pulling it upwards with caution.
  7. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 7 中的图像 1,1
    • Use a long #2 Philips head to remove the two screws from the arched grey piece.
  8. Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 8 中的图像 1,2 Hoover Power Path Pro Advanced Power Switch Replacement: 步骤 8 中的图像 2,2
    • Pull out the red power the red power switch.
结论
4等其他人完成本指南。
团队
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G5
5 名成员
创作了15篇指南
3指南评论
What is the part number?
martahayner - 回复
Thanks so much!!
debmccrimm - 回复
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 19
总计 4,019
