跳转到主内容
Hoover Power Path Pro Advanced Hose Replacement
你所需要的
  1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: 步骤 1 中的图像 1,2 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: 步骤 1 中的图像 2,2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
    I have to rollers on mine.
    poco24 - 回复
    I have two rollers on mine.
    poco24 - 回复
  2. Hoover Power Path Pro Advanced Hose Replacement: 步骤 2 中的图像 1,2 Hoover Power Path Pro Advanced Hose Replacement: 步骤 2 中的图像 2,2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Hose Replacement: 步骤 3 中的图像 1,1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
    Removing long roller brush is not required and can’t be done at this point because of belt.
    frank wilbanks - 回复
    Yuck!! I want to clean the transparent curved surface. I can’t get at it.
    jmariep - 回复
  4. Hoover Power Path Pro Advanced Hose Replacement, Hose: 步骤 4 中的图像 1,1
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    • They will also be indicated on the bottom of the vacuum.
  5. Hoover Power Path Pro Advanced Hose Replacement: 步骤 5 中的图像 1,2 Hoover Power Path Pro Advanced Hose Replacement: 步骤 5 中的图像 2,2
    • Pull the red handle shown to remove the front suction unit from the cleaner.
    I need to find a front suction unit for this exact carpet cleaner
    Carl Hasty - 回复
    Does anyone know where i can get a new front suction unit for this style carpet cleaner
    Carl Hasty -
  6. Hoover Power Path Pro Advanced Hose Replacement: 步骤 6 中的图像 1,1
    • Unscrew the Phillips #2 screw at the bottom of the hose.
  7. Hoover Power Path Pro Advanced Hose Replacement: 步骤 7 中的图像 1,1
    • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
结论
3等其他人完成本指南。
团队
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S16G5
5 名成员
创作了15篇指南
4条评论
Where can I find this replacement hose?
Jennifer - 回复
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - 回复
Where can I purchase the lower hose?
Eryk H. - 回复
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 4,237
