跳转到主内容
Hoover LiNX The Nozzle Prongs Replacement
你所需要的
  1. Hoover LiNX The Nozzle Prongs Replacement, Replace The Motor: 步骤 1 中的图像 1,1
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX The Nozzle Prongs Replacement: 步骤 2 中的图像 1,1
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX The Nozzle Prongs Replacement: 步骤 3 中的图像 1,2 Hoover LiNX The Nozzle Prongs Replacement: 步骤 3 中的图像 2,2
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX The Nozzle Prongs Replacement: 步骤 4 中的图像 1,1
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX The Nozzle Prongs Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom panel.
  6. Hoover LiNX The Nozzle Prongs Replacement: 步骤 6 中的图像 1,1
    • Remove the motor.
  7. Hoover LiNX The Nozzle Prongs Replacement, The Nozzle Prongs: 步骤 7 中的图像 1,1
    • Remove the two 7.5mm Phillips #1 screws from the main body.
  8. Hoover LiNX The Nozzle Prongs Replacement: 步骤 8 中的图像 1,1
    • Remove the black covering from the air tube.
  9. Hoover LiNX The Nozzle Prongs Replacement: 步骤 9 中的图像 1,1
    • Slide the prongs out through their channels.
  10. Hoover LiNX The Nozzle Prongs Replacement: 步骤 10 中的图像 1,2 Hoover LiNX The Nozzle Prongs Replacement: 步骤 10 中的图像 2,2
    • Remove the angled neck and feed the prongs out through their channels.
  11. Hoover LiNX The Nozzle Prongs Replacement: 步骤 11 中的图像 1,2 Hoover LiNX The Nozzle Prongs Replacement: 步骤 11 中的图像 2,2
    • Replace the prongs.
结论
2等其他人完成本指南。
Sara Vlhova
于01/25/18注册
541 声望
创作了4篇指南
团队
USF Tampa, Team S7-G4, Passmore Spring 2018 USF Tampa, Team S7-G4, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G4
4 名成员
创作了12篇指南
2条评论
How do I get to the receivers for the prongs? They appear to be too loose to make a connection and i have not been able to get into the body to tighten. Is there another way to improve this connection?
Robert L Worthing - 回复
Thank you for asking ifixit your 11/1018 question. I’ve been trying to disassemble the body to get at the receiver(s)/socket(s) for those prongs for days. And ifixit, please, have you got a picture of the routing of the brush motor wires from the motor through the rolling assembly, the swiveling universal joint, and along the back of the airtube?
donwesel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 34
总计 1,724
