跳转到主内容
Hoover LiNX The Motherboard Inside The Handle Replacement
你所需要的
  1. Hoover LiNX The Motherboard Inside The Handle  Replacement, Hoover LiNX Handle Teardown: 步骤 1 中的图像 1,1
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 2 中的图像 1,1
    • Remove the handle by pulling it up.
  3. Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 3 中的图像 1,1
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 4 中的图像 1,2 Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 5 中的图像 1,2 Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 5 中的图像 2,2
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 6 中的图像 1,2 Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 6 中的图像 2,2
    • Remove the silver plastic cover using the plastic opening tool.
  7. Hoover LiNX The Motherboard Inside The Handle  Replacement, The Motherboard Inside The Handle: 步骤 7 中的图像 1,1
    • Remove the black rubber cover from the motherboard.
  8. Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 8 中的图像 1,1
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 9 中的图像 1,2 Hoover LiNX The Motherboard Inside The Handle  Replacement: 步骤 9 中的图像 2,2
    • Carefully pull the motherboard out with its attached wires.
结论
另外一个人完成了本指南。
Sara Vlhova
于01/25/18注册
541 声望
创作了4篇指南
团队
USF Tampa, Team S7-G4, Passmore Spring 2018 USF Tampa, Team S7-G4, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S7G4
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 10
总计 896
