跳转到主内容
Honeywell Turboforce Motor Replacement
你所需要的
  1. Honeywell Turboforce Motor Replacement, Motor: 步骤 1 中的图像 1,3 Honeywell Turboforce Motor Replacement, Motor: 步骤 1 中的图像 2,3 Honeywell Turboforce Motor Replacement, Motor: 步骤 1 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the six 15mm screws on the outer ring of the back of the fan holding the frame together.
    • The screw channel is long and it is recommended to use a screwdriver with a long shaft or a screwdriver with a skinnier handle.
  2. Honeywell Turboforce Motor Replacement: 步骤 2 中的图像 1,3 Honeywell Turboforce Motor Replacement: 步骤 2 中的图像 2,3 Honeywell Turboforce Motor Replacement: 步骤 2 中的图像 3,3
    • Pry apart the blade cover from the body of the fan to access the inside.
  3. Honeywell Turboforce Motor Replacement: 步骤 3 中的图像 1,2 Honeywell Turboforce Motor Replacement: 步骤 3 中的图像 2,2
    • Remove the two 36mm screws on the metal plate behind the blades using the Phillips #1 screwdriver.
  4. Honeywell Turboforce Motor Replacement: 步骤 4 中的图像 1,2 Honeywell Turboforce Motor Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the motor forward out of its resting position and tilt it forward revealing the back of the motor.
    • Beware of the wires attached to the back of the motor.
  5. Honeywell Turboforce Motor Replacement: 步骤 5 中的图像 1,3 Honeywell Turboforce Motor Replacement: 步骤 5 中的图像 2,3 Honeywell Turboforce Motor Replacement: 步骤 5 中的图像 3,3
    • Using the Phillips #1 screwdriver, remove the two 37mm screws on the back of the motor.
    • Beware that there is a nut holding the screw in place on the opposite side of the motor.
    • Beware once the screw is removed the metal brace where the screws are located will come off.
  6. Honeywell Turboforce Motor Replacement: 步骤 6 中的图像 1,2 Honeywell Turboforce Motor Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the circular motor from the square holder.
    • The fan blades will still be connected to the circular motor.
  7. Honeywell Turboforce Motor Replacement: 步骤 7 中的图像 1,3 Honeywell Turboforce Motor Replacement: 步骤 7 中的图像 2,3 Honeywell Turboforce Motor Replacement: 步骤 7 中的图像 3,3
    • Remove the felt washer, metal washer, and the rubber stopper from the axle.
  8. Honeywell Turboforce Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the motor and replace it with the new part.
    • Consider using a lubricant to insert the new motor.
    Very helpful and systematic. Thought I needed a new motor. Turns out all I needed was a cleaning and some WD40
    Krupal Shah - 回复
    Any links or pointers where to get this replacement motor? I’m looking to replace 120v with 240v any thoughts ?
    Dario Matonicki - 回复
    The fan you are replacing is NOT the same as what I own. Mine is a model HV180. It looks similar but is 19" OD and has a 2part housing that looks to be a bare to open. Looks best to cut the little wire angles off and replace the motor. To reassemble put it together with zip ties and then use a mig welder to make it firmer and safer for a longer life!!
    McGyver - 回复
结论
10等其他人完成本指南。
5条评论
What is the motor parts details to procure elsewhere?
patra gyanesh - 回复
Hi informative guide but first how do we get the new motor how do you remove the blade nut to remove the blade from the old motor shaft
Dave Gordon - 回复
Given the difficulty of finding a replacement motor with three speeds and the correct mounting configuration, it makes more sense to buy a new model of this fan. Much faster, too.
Sprockets John
John Sprockets - 回复
Top notch how to document! Commentary and photos are excellent. Good job! And thank you very much
M Robarton - 回复
Where are y’all finding the motor? Please advise… this looks doable! Thank you for your assistance. Michelle
Michelle Paredes - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 36
过去 30 天: 140
总计 8,315
