跳转到主内容
Honeywell HY-254-TGT Front Panel Replacement
你所需要的
  1. Honeywell HY-254-TGT Front Panel Replacement, Plastic Assembly: 步骤 1 中的图像 1,1
    • Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
  2. Honeywell HY-254-TGT Front Panel Replacement: 步骤 2 中的图像 1,3 Honeywell HY-254-TGT Front Panel Replacement: 步骤 2 中的图像 2,3 Honeywell HY-254-TGT Front Panel Replacement: 步骤 2 中的图像 3,3
    • Twist the fan base counter-clockwise until the pins line up as shown.
    • Pull the base straight towards you to remove it, feeding the wire through the base.
  3. Honeywell HY-254-TGT Front Panel Replacement: 步骤 3 中的图像 1,1
    • Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
    • Remove the two marked 3/4" Phillips #02 screws in the middle.
  4. Honeywell HY-254-TGT Front Panel Replacement: 步骤 4 中的图像 1,3 Honeywell HY-254-TGT Front Panel Replacement: 步骤 4 中的图像 2,3 Honeywell HY-254-TGT Front Panel Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
    • Be aware of two clips inside the fan, towards the bottom third of the fan. If the back appears stuck on certain spots, push inward edges of the front casing around the problematic area.
  5. Honeywell HY-254-TGT Front Panel Replacement, Front Panel: 步骤 5 中的图像 1,2 Honeywell HY-254-TGT Front Panel Replacement, Front Panel: 步骤 5 中的图像 2,2
    • Remove the four 1/2" Phillips #02 screws, indicated by a red circle.
    • Lean the front panel forwards and set it down.
    • The front panel will not fully detach and cannot be removed. Do not try to forcibly remove it, as it may cause damage to the electronics.
  6. Honeywell HY-254-TGT Front Panel Replacement: 步骤 6 中的图像 1,2 Honeywell HY-254-TGT Front Panel Replacement: 步骤 6 中的图像 2,2
    • Gently lift and remove the panel covering the electronics assembly.
  7. Honeywell HY-254-TGT Front Panel Replacement: 步骤 7 中的图像 1,3 Honeywell HY-254-TGT Front Panel Replacement: 步骤 7 中的图像 2,3 Honeywell HY-254-TGT Front Panel Replacement: 步骤 7 中的图像 3,3
    • Remove the four 1/2" Phillips #01 screws in the circuit board.
    • Gently pull the circuit board off of the rest of the front panel assembly.
  8. Honeywell HY-254-TGT Front Panel Replacement: 步骤 8 中的图像 1,3 Honeywell HY-254-TGT Front Panel Replacement: 步骤 8 中的图像 2,3 Honeywell HY-254-TGT Front Panel Replacement: 步骤 8 中的图像 3,3
    • Lift out the internal part of the front panel to access the buttons.
  9. Honeywell HY-254-TGT Front Panel Replacement: 步骤 9 中的图像 1,1
    • If necessary, remove the buttons by grabbing them with two fingers and pulling up and away from the panel.
    • Upon reassembly, ensure buttons are placed in the correct location.
结论
另外一个人完成了本指南。
Darian Maxwell
于10/01/15注册
381 声望
创作了2篇指南
团队
Cal Poly, Team 11-6, Forte Fall 2015 Cal Poly, Team 11-6, Forte Fall 2015 的会员
CPSU-FORTE-F15S11G6
4 名成员
创作了4篇指南
2条评论
the piece to make it turn is broken
clara rojas - 回复
the piece that make it turn is broken!
clara rojas - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 16
总计 5,326
