跳转到主内容
Honeywell HY-204 Rotation Motor Replacement
你所需要的
  1. Honeywell HY-204 Rotation Motor Replacement, Rotation Motor: 步骤 1 中的图像 1,1
    • Before you begin, be sure to unplug the fan.
    • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  2. Honeywell HY-204 Rotation Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the three 12mm screws using the Phillips #0 Screwdriver.
  3. Honeywell HY-204 Rotation Motor Replacement: 步骤 3 中的图像 1,2 Honeywell HY-204 Rotation Motor Replacement: 步骤 3 中的图像 2,2
    • Remove the two 10mm screws using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Motor Replacement: 步骤 4 中的图像 1,1
    • Move the rotation motor left and right to reveal the screw connecting it to the fan.
    • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
  5. Honeywell HY-204 Rotation Motor Replacement: 步骤 5 中的图像 1,1
    • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
    • To put back together you will need to resolder or use wire connectors to reattach motor.
结论
团队
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G40
3 名成员
创作了7篇指南
2条评论
It seems that these instructions are on “How to eeplacr the oscillation motor". But they neglect the requirement to have a replacement motor or how/where to get the replacement motor. Otherwise the steps seem clear.
Alan A. Kopta - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 17
总计 2,656
