跳转到主内容
Honeywell HY-204 Fan Blades Replacement
你所需要的
  1. Honeywell HY-204 Fan Blades Replacement, Case: 步骤 1 中的图像 1,2 Honeywell HY-204 Fan Blades Replacement, Case: 步骤 1 中的图像 2,2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Blades Replacement: 步骤 2 中的图像 1,2 Honeywell HY-204 Fan Blades Replacement: 步骤 2 中的图像 2,2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Blades Replacement, Fan Blades: 步骤 3 中的图像 1,2 Honeywell HY-204 Fan Blades Replacement, Fan Blades: 步骤 3 中的图像 2,2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Blades Replacement: 步骤 4 中的图像 1,2 Honeywell HY-204 Fan Blades Replacement: 步骤 4 中的图像 2,2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
结论
Jenna Johnson
于10/14/14注册
247 声望
撰写一个指南
团队
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G40
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 24
总计 3,029
