跳转到主内容
Honeywell HY-204 Control Panel Replacement
你所需要的
  1. Honeywell HY-204 Control Panel Replacement, Case: 步骤 1 中的图像 1,2 Honeywell HY-204 Control Panel Replacement, Case: 步骤 1 中的图像 2,2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Control Panel Replacement: 步骤 2 中的图像 1,2 Honeywell HY-204 Control Panel Replacement: 步骤 2 中的图像 2,2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Control Panel Replacement, Control Panel: 步骤 3 中的图像 1,2 Honeywell HY-204 Control Panel Replacement, Control Panel: 步骤 3 中的图像 2,2
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Control Panel Replacement: 步骤 4 中的图像 1,1
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
结论
Nolan Ernotte
于10/14/14注册
366 声望
创作了3篇指南
团队
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 的会员
CPSU-AMIDO-F14S10G40
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 527
