简介
There are a number of potential causes if your Honeywell HT900C fan does not start when you turn it on, including the fan motor being damaged from overuse, the fan being misaligned, etc. The fan motor is the most common culprit because it drives the rest of the fan. Our instructions will guide you through disassembling the old motor and installing the new one. All that is required is a screwdriver and some lubricant, both of which can be found in almost every home.
你所需要的
Remove the six 15 mm screws securing the fan's frame to its outer ring on the back using a Phillips #1 screwdriver.
另外一个人完成了本指南。
