跳转到主内容
Honeytone N-10 Mini Amp Speaker Replacement
你所需要的
  1. Honeytone N-10 Mini Amp Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Honeytone N-10 Mini Amp Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Flip your amp over to begin removing the plastic cover.
  2. Honeytone N-10 Mini Amp Speaker Replacement: 步骤 2 中的图像 1,2 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 2 中的图像 2,2
    • Remove the battery cover and take the battery out.
    • Unless you want a quick pick-me-up, in which case feel free to leave it in and get shocked.
  3. Honeytone N-10 Mini Amp Speaker Replacement: 步骤 3 中的图像 1,2 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 3 中的图像 2,2
    • Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
    • While the screws are recessed deep into the cover and difficult to see, 2-4 turns will easily release them.
  4. Honeytone N-10 Mini Amp Speaker Replacement: 步骤 4 中的图像 1,3 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 4 中的图像 2,3 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the back cover by carefully pushing the battery connector through the hole in the cover.
  5. Honeytone N-10 Mini Amp Speaker Replacement: 步骤 5 中的图像 1,3 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 5 中的图像 2,3 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 5 中的图像 3,3
    • With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
  6. Honeytone N-10 Mini Amp Speaker Replacement: 步骤 6 中的图像 1,2 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 6 中的图像 2,2
    • Use flush wire cutters to remove black and red wires from the old speaker.
    • Note: The black wire has already been removed in this example image.
  7. Honeytone N-10 Mini Amp Speaker Replacement: 步骤 7 中的图像 1,3 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 7 中的图像 2,3 Honeytone N-10 Mini Amp Speaker Replacement: 步骤 7 中的图像 3,3
    • Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
  8. Honeytone N-10 Mini Amp Speaker Replacement: 步骤 8 中的图像 1,1
    • Connect the battery and turn the power on to test proper connection of the new speaker.
    • Some static is fine, this is the natural sound of the amp.
    • Careful not to touch any of the metal components inside while temporarily testing the connection.
  9. Honeytone N-10 Mini Amp Speaker Replacement: 步骤 9 中的图像 1,1
    • Reverse steps 1-5 to complete repair.
    • Connect the amp to your favorite instrument and test out the new sound!
终点
3等其他人完成本指南。
Corey Brown
于06/24/16注册
8,682 声望
创作了11篇指南
一条评论
Cool. If mine doesn’t work, is it likely to be the speaker? Thanks.
hupaand - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 3,489
