Some soldering will be required in order to complete the speaker replacement.
Remove the battery cover and take the battery out.
Unless you want a quick pick-me-up, in which case feel free to leave it in and get shocked.
Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
While the screws are recessed deep into the cover and difficult to see, 2-4 turns will easily release them.
Connect the battery and turn the power on to test proper connection of the new speaker.
Some static is fine, this is the natural sound of the amp.
Careful not to touch any of the metal components inside while temporarily testing the connection.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
