简介
Use this guide to remove or replace the tine oil seal in a Honda Light Duty Tiller F220K1AT715492.
You will need to support the tiller during this process. Use jack stands, large pieces of wood, or other strong supports. Rock the tiller back and forth on its supports before beginning to ensure that it won’t fall or tip over during repairs. Make sure you can still remove the right-side tines while the tiller is supported.
Drain the oil before you begin this procedure. Any remaining oil will spill out when you remove the seal. Be ready to contain any spillage.
You will need to refill the engine oil after this procedure. The recommended oil is 10W-30.
你所需要的
Pull the snap pin straight out of the pin securing the right tine to the tine shaft.
The tine shaft pin may fall out when you remove the snap pin. If the tine shaft pin did not fall out, remove it now.
Slide an angled pick under the inner ring of the seal so that you can pry the seal out of the reduction case.
Pry the seal out of the reduction case, taking care not to mar the aluminum reduction case.
Remove the oil seal.
Refill the oil after reassembly.
7等其他人完成本指南。
