跳转到主内容
Honda Fit Reset Oil Life Indicator Replacement
你所需要的
    • Turn the key in the ignition to the run position (right before the start position)
    • Press the SELECT/RESET knob repeatedly until the engine oil life indicator is displayed.
    • Press and hold the SELECT/RESET knob for more than 10 seconds. The engine oil life indicator and the maintenance code(s) will blink.
    • Press and hold the SELECT/RESET knob for more than 5 seconds. The maintenance items code(s) will disappear, and the engine oil life will reset to 100%.
    • Turn the key in the ignition to the off position, and then start the engine to verify the indicator has been reset.
结论
You did it!
19等其他人完成本指南。
Jasen Friedle
于08/25/14注册
3,821 声望
创作了3篇指南
5条评论
Great. I did it—and I’m a girl!!
pthompso99 - 回复
Excellent! Glad to hear it.
Jasen Friedle - 回复
in my case i followed the step through. 100% oil life was achieved but when i turn the ignition off and turn it back on to verify, it goes back to 15%
Esosa Aghimien - 回复
And how can I start the car that it won't start
sbukataake - 回复
Have you tried changing your blinker fluid?
neegnorg -
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 127
过去 30 天: 509
总计 75,161
