跳转到主内容
Honda FC600 Tiller Tine Replacement
你所需要的
  1. Honda FC600 Tiller Tine Replacement, Remove the Spark Plug Cap: 步骤 1 中的图像 1,3 Honda FC600 Tiller Tine Replacement, Remove the Spark Plug Cap: 步骤 1 中的图像 2,3 Honda FC600 Tiller Tine Replacement, Remove the Spark Plug Cap: 步骤 1 中的图像 3,3
    • Before you begin, it's important that you completely cut power to the tiller by disconnecting the spark plug. This will prevent the engine from accidentally starting up while you're working on the tiller.
    • Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
  2. Honda FC600 Tiller Tine Replacement, Prop Up the Tiller: 步骤 2 中的图像 1,1
    • The next two steps demonstrate how to prop up the tiller to work on the tines.
    • Set down a block (or blocks) of wood onto your work surface.
    • Make sure the wood blocks are narrow enough to fit in between the left- and right-side tines.
  3. Honda FC600 Tiller Tine Replacement: 步骤 3 中的图像 1,3 Honda FC600 Tiller Tine Replacement: 步骤 3 中的图像 2,3 Honda FC600 Tiller Tine Replacement: 步骤 3 中的图像 3,3
    • Lift and roll the tiller over the wood block until the center of the tine axle is hovering over the wood block.
    • Gently set the tiller down so that the center of the tine axle rests on the wood block.
    • You may need to lean the tiller to one side to make sure the tines on the other side are completely off the work surface.
  4. Honda FC600 Tiller Tine Replacement: 步骤 4 中的图像 1,1
    • Place a block (or blocks) of wood under the tiller's drag bar to prevent the tiller from leaning back.
  5. Honda FC600 Tiller Tine Replacement, Remove the Tine: 步骤 5 中的图像 1,3 Honda FC600 Tiller Tine Replacement, Remove the Tine: 步骤 5 中的图像 2,3 Honda FC600 Tiller Tine Replacement, Remove the Tine: 步骤 5 中的图像 3,3
    • Remove the two 14 mm nuts securing the tine to the mounting bracket.
    • It is not required to remove the side disc.
    • Depending on which tine you're replacing, you may need to remove different nuts.
  6. Honda FC600 Tiller Tine Replacement: 步骤 6 中的图像 1,2 Honda FC600 Tiller Tine Replacement: 步骤 6 中的图像 2,2
    • Grab the tine and pull it straight off of the mounting bracket.
    • Removing the bolts is not required.
结论
Craig Lloyd
于02/10/16注册
41,240 声望
创作了82篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 2,286
