跳转到主内容
Honda FC600 Tiller Throttle Lever Replacement
你所需要的
  1. Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 步骤 1 中的图像 1,3 Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 步骤 1 中的图像 2,3 Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 步骤 1 中的图像 3,3
    • Before you begin, it's important that you completely cut power to the tiller by disconnecting the spark plug. This will prevent the engine from accidentally starting up while you're working on the tiller.
    • Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
  2. Honda FC600 Tiller Throttle Lever Replacement, Preparation: 步骤 2 中的图像 1,2 Honda FC600 Tiller Throttle Lever Replacement, Preparation: 步骤 2 中的图像 2,2
    • Push the throttle lever all the way down.
  3. Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Lever: 步骤 3 中的图像 1,1
    • Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
    • This screw is accompanied by a square nut. Be sure to retain it for reassembly.
  4. Honda FC600 Tiller Throttle Lever Replacement, Remove the Small Throttle Cable Clip: 步骤 4 中的图像 1,2 Honda FC600 Tiller Throttle Lever Replacement, Remove the Small Throttle Cable Clip: 步骤 4 中的图像 2,2
    • Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
  5. Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Cable: 步骤 5 中的图像 1,2 Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Cable: 步骤 5 中的图像 2,2
    • Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
  6. Honda FC600 Tiller Throttle Lever Replacement: 步骤 6 中的图像 1,3 Honda FC600 Tiller Throttle Lever Replacement: 步骤 6 中的图像 2,3 Honda FC600 Tiller Throttle Lever Replacement: 步骤 6 中的图像 3,3
    • Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess.
结论
另外一个人完成了本指南。
Craig Lloyd
于02/10/16注册
35,421 声望
创作了82篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 786
