跳转到主内容
Honda CSC29 Voltage Regulator Replacement
你所需要的
  1. Honda CSC29 Voltage Regulator Replacement, Alternator Front Cover: 步骤 1 中的图像 1,3 Honda CSC29 Voltage Regulator Replacement, Alternator Front Cover: 步骤 1 中的图像 2,3 Honda CSC29 Voltage Regulator Replacement, Alternator Front Cover: 步骤 1 中的图像 3,3
    • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
    • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
    • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
  2. Honda CSC29 Voltage Regulator Replacement: 步骤 2 中的图像 1,3 Honda CSC29 Voltage Regulator Replacement: 步骤 2 中的图像 2,3 Honda CSC29 Voltage Regulator Replacement: 步骤 2 中的图像 3,3
    • Pull cover off the body of the alternator
    • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
  3. Honda CSC29 Voltage Regulator Replacement, Removing the brush assembly.: 步骤 3 中的图像 1,3 Honda CSC29 Voltage Regulator Replacement, Removing the brush assembly.: 步骤 3 中的图像 2,3 Honda CSC29 Voltage Regulator Replacement, Removing the brush assembly.: 步骤 3 中的图像 3,3
    • With the alternator cover removed, use a #2 Phillips screwdriver to remove the two, 6 mm screws that hold the brush cover in place.
    • Remove the brush cover assembly from the alternator. You might need to insert a needle in the small hole to separate the brushes from the rotor. Pull it out without using much force to avoid damage.
    • Avoid disconnecting wires unless otherwise specified!
  4. Honda CSC29 Voltage Regulator Replacement: 步骤 4 中的图像 1,3 Honda CSC29 Voltage Regulator Replacement: 步骤 4 中的图像 2,3 Honda CSC29 Voltage Regulator Replacement: 步骤 4 中的图像 3,3
    • Use a #2 Phillips screwdriver to remove the two 6mm screws holding down the voltage regulator
    • There are three screws that attach the voltage regulator to the bridge assembly. One of these screws was removed in the previous step.
  5. Honda CSC29 Voltage Regulator Replacement: 步骤 5 中的图像 1,1
    • Locate and unscrew the 3, 6mm screws holding the bridge assembly in place
    • There are 4 screws attaching the bridge assembly to the alternator. One of these screws were removed in the previous step.
  6. Honda CSC29 Voltage Regulator Replacement: 步骤 6 中的图像 1,2 Honda CSC29 Voltage Regulator Replacement: 步骤 6 中的图像 2,2
    • Locate the copper leads connecting the stator to the bridge assembly. There are 3 sets of 2 leads on the perimeter of the bridge, making 6 leads total.
    • These leads must be cut in order to remove the bridge from the alternator. These leads will have to be soldered back together on reassembly. Keep the cut as clean as possible.
    • Use wire cutters to cut all 6 of the leads on the perimeter of the bridge.
  7. Honda CSC29 Voltage Regulator Replacement: 步骤 7 中的图像 1,3 Honda CSC29 Voltage Regulator Replacement: 步骤 7 中的图像 2,3 Honda CSC29 Voltage Regulator Replacement: 步骤 7 中的图像 3,3
    • If necessary, use a pry bar to gently raise the top of the bridge assembly off the alternator
    • Be extremely careful with the pry bar. Excessive force will damage the bridge assembly.
    • Make sure the cut ends of the copper leads are straight to make bridge assembly easier to pull off.
  8. Honda CSC29 Voltage Regulator Replacement: 步骤 8 中的图像 1,3 Honda CSC29 Voltage Regulator Replacement: 步骤 8 中的图像 2,3 Honda CSC29 Voltage Regulator Replacement: 步骤 8 中的图像 3,3
    • Remove the lower section of the bridge assembly
    • Use of a pry bar may be necessary. Be gentle.
  9. Honda CSC29 Voltage Regulator Replacement, Voltage Regulator: 步骤 9 中的图像 1,2 Honda CSC29 Voltage Regulator Replacement, Voltage Regulator: 步骤 9 中的图像 2,2
    • Locate the small metal clasp attaching the voltage regulator to the the rectifier.
    • Loosen the clasp using a pair of needle-nose pliers
  10. Honda CSC29 Voltage Regulator Replacement: 步骤 10 中的图像 1,2 Honda CSC29 Voltage Regulator Replacement: 步骤 10 中的图像 2,2
    • Using a pair of wire cutters, cut the copper winding attaching the voltage regulator to the rectifier
    • Be very careful with any cuts. Keep them as clean as possible, as any severed connections will need to be soldered on reassembly.
  11. Honda CSC29 Voltage Regulator Replacement: 步骤 11 中的图像 1,3 Honda CSC29 Voltage Regulator Replacement: 步骤 11 中的图像 2,3 Honda CSC29 Voltage Regulator Replacement: 步骤 11 中的图像 3,3
    • Remove the voltage regulator from the alternator
    • When connecting the new voltage regulator, carefully read the manufacturer's instructions on how to connect it to different types of alternators.
结论
6等其他人完成本指南。
Sterling Snow
于04/14/16注册
173 声望
撰写一个指南
团队
Cal Poly, Team 25-1, Maness Spring 2016 Cal Poly, Team 25-1, Maness Spring 2016 的会员
CPSU-MANESS-S16S25G1
4 名成员
创作了15篇指南
一条评论
Very good instructions
Moe Lauzon - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 12
过去 30 天: 75
总计 9,057
