简介
Are you having issues with sluggish electrical components in your Honda? An issue with the Diode Trio on your Alternator's Rectifier Bridge will cause voltage to leak from your car battery, hampering its performance. The diodes act like one-way check valves, splitting AC current into a positive and negative branch that redirected to the positive and ground terminals of the car battery.
你所需要的
With the alternator cover removed, use a #2 Phillips screwdriver to remove the two, 6 mm screws that hold the brush cover in place.
Remove the brush cover assembly from the alternator. You might need to insert a needle in the small hole to separate the brushes from the rotor. Pull it out without using much force to avoid damage.
4等其他人完成本指南。
