跳转到主内容
Honda CSC29 Alternator Cover Removal
你所需要的
  1. Honda CSC29 Alternator Cover Removal, Alternator Front Cover: 步骤 1 中的图像 1,3 Honda CSC29 Alternator Cover Removal, Alternator Front Cover: 步骤 1 中的图像 2,3 Honda CSC29 Alternator Cover Removal, Alternator Front Cover: 步骤 1 中的图像 3,3
    • Remove 4, 7.9mm nuts using a 7.9mm socket driver head
    • One of the nuts is placed underneath the L-Bracket. Remove the L-Bracket and the 3 circled nuts before attempting to remove the remaining nut
    • There are two covers that need to be removed from the alternator. This step describes how to remove the back cover.
  2. Honda CSC29 Alternator Cover Removal: 步骤 2 中的图像 1,3 Honda CSC29 Alternator Cover Removal: 步骤 2 中的图像 2,3 Honda CSC29 Alternator Cover Removal: 步骤 2 中的图像 3,3
    • Pull cover off the body of the alternator
    • Once you have done this, you should be able to see the internal components of the alternator, particularly the bridge assembly that houses the rectifier, voltage regulator and brushes.
结论
8等其他人完成本指南。
团队
Cal Poly, Team 25-1, Maness Spring 2016 Cal Poly, Team 25-1, Maness Spring 2016 的会员
CPSU-MANESS-S16S25G1
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 1,834
