跳转到主内容
Honda CRF250L Exhaust Replacement
你所需要的
  1. Honda CRF250L Exhaust Replacement, Honda CRF250L Exhaust: 步骤 1 中的图像 1,3 Honda CRF250L Exhaust Replacement, Honda CRF250L Exhaust: 步骤 1 中的图像 2,3 Honda CRF250L Exhaust Replacement, Honda CRF250L Exhaust: 步骤 1 中的图像 3,3
    • Take off the existing exhaust.
    • Remove the external hex bolt by the header with the 1/2" socket.
    • Then, remove the internal hex socket bolt by the exhaust with the 6mm Allen wrench.
    • When unscrewing the bolt by the exhaust, make sure to hold the nut stationary with the 1/2" open-ended wrench.
  2. Honda CRF250L Exhaust Replacement: 步骤 2 中的图像 1,1
    • Slide the pipe into the the exhaust.
    • The pipe should curve downward.
  3. Honda CRF250L Exhaust Replacement: 步骤 3 中的图像 1,2 Honda CRF250L Exhaust Replacement: 步骤 3 中的图像 2,2
    • Hook the spring on to one of the slots that is welded on the pipe and exhaust.
    • Then, expand the spring to hook around the opposing slot using the spring hook.
  4. Honda CRF250L Exhaust Replacement: 步骤 4 中的图像 1,1
    • Slide the clamp over the end of the pipe.
    • Make sure the bolt is stationed on top to tighten later.
  5. Honda CRF250L Exhaust Replacement: 步骤 5 中的图像 1,1
    • Slide the mount over the exhaust.
  6. Honda CRF250L Exhaust Replacement: 步骤 6 中的图像 1,1
    • Slide the new exhaust onto the header.
    • The exhaust should curve upward.
  7. Honda CRF250L Exhaust Replacement: 步骤 7 中的图像 1,2 Honda CRF250L Exhaust Replacement: 步骤 7 中的图像 2,2
    • Make sure that the mount is positioned to allow all holes to line up.
    • Insert the internal hex socket bolt.
  8. Honda CRF250L Exhaust Replacement: 步骤 8 中的图像 1,3 Honda CRF250L Exhaust Replacement: 步骤 8 中的图像 2,3 Honda CRF250L Exhaust Replacement: 步骤 8 中的图像 3,3
    • Insert the bolt attached to the mount.
    • Install the nut to the backside of the internal hex socket bolt.
    • Tighten the internal hex socket bolt using the 6mm Allen wrench.
    • Keep the nut stationary using the 1/2" open-ended wrench.
  9. Honda CRF250L Exhaust Replacement: 步骤 9 中的图像 1,1
    • Tighten the clamp.
    • Tighten the internal hex socket bolt on the clamp using the 6mm Allen wrench.
结论
To reassemble your stock exhaust, follow these instructions in reverse order.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 77
总计 1,390
