跳转到主内容
Honda CR-V 2006-2010 Weatherstripping Replacement
你所需要的
  1. Honda CR-V 2006-2010 Weatherstripping Replacement, Weatherstripping: 步骤 1 中的图像 1,3 Honda CR-V 2006-2010 Weatherstripping Replacement, Weatherstripping: 步骤 1 中的图像 2,3 Honda CR-V 2006-2010 Weatherstripping Replacement, Weatherstripping: 步骤 1 中的图像 3,3
    • Identify how much of the stripping is detached by lightly pulling down on the rubberized material.
  2. Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 2 中的图像 1,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 2 中的图像 2,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 2 中的图像 3,3
    • Clean the surfaces that need to be reattached. This is easily done with brake cleaner.
    • Apply brake cleaner directly to the metal parts of the door where the weatherstripping was attached and wipe it dry with a microfiber towel.
    • Spray brake cleaner onto the towel and wipe along the backside of the weatherstripping (the side that touches the car).
  3. Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 3 中的图像 1,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 3 中的图像 2,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 3 中的图像 3,3
    • Once the cleaner has dried, take your silicone/ waterproof sealant and apply thick, evenly spread beads to the backside of the weatherstripping.
  4. Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 4 中的图像 1,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 4 中的图像 2,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 4 中的图像 3,3
    • Press the weatherstripping firmly into its seated position.
  5. Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 5 中的图像 1,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 5 中的图像 2,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 5 中的图像 3,3
    • Check to make sure the weatherstripping is in the correct position or if there are any spots that appear to be out of alignment,
    • If it appears to be in place, hold the weatherstripping down with masking or painters tape.
  6. Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 6 中的图像 1,2 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 6 中的图像 2,2
    • Wipe away any excess adhesive with a clean microfiber towel that has been sprayed with brake cleaner.
  7. Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 7 中的图像 1,2 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 7 中的图像 2,2
    • To make sure that the weatherstripping has been properly attached, close the car door and observe the edges where the weatherstripping is present. If there are parts where the weatherstripping is bulging out or is not present, realign and close the door again.
    • With the stripping correctly in place, close the door and let the adhesive dry.
    • This will ensure that the adhesive holds the stripping in the optimal position.
  8. Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 8 中的图像 1,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 8 中的图像 2,3 Honda CR-V 2006-2010 Weatherstripping Replacement: 步骤 8 中的图像 3,3
    • In order to prevent moisture from staying behind your weatherstripping which causes it to detach, apply silicone spray to it.
    • After the adhesive has fully cured, spray silicone spray directly between the door and the weatherstrippings overhang and spray directly on it.
    • Wipe with a clean microfiber towel to apply evenly.
    • This step will also help the lifespan of your weatherstripping by protecting it from dry rot.
结论
Door weatherstripping is commonly detached from the car door due to moisture getting behind the stripping and then freezing in colder weather. When the door is opened, the weatherstripping is pulled off. This can be fixed with some cleaning and sealant and can be prevented in the future with silicone spray.
Madison Higgins
于02/26/21注册
157 声望
撰写一个指南
一条评论
Great writeup. I'm pretty sure thst is a 2002-2006 model CR-V. I own a 2002 exactly the same as this one.
David Davidson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 81
总计 1,988
