跳转到主内容
Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement
你所需要的
  1. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement, Disconnect the spark plug: 步骤 1 中的图像 1,2 Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement, Disconnect the spark plug: 步骤 1 中的图像 2,2
    • Before you begin, disconnect the spark plug connector from the spark plug.
  2. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement, Unfasten the cyclo converter cover: 步骤 2 中的图像 1,1
    • Use a 10 mm socket to remove the nut securing the top of the cyclo converter cover.
    • Use a 10 mm socket to remove the bolt securing the bottom of the cyclo converter cover.
  3. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 3 中的图像 1,3 Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 3 中的图像 2,3 Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 3 中的图像 3,3
    • Un-slot the two black rubber cable grommets from the top and right edge of the plastic cover.
    • Remove the cyclo converter cover.
  4. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement, Disconnect the cyclo converter: 步骤 4 中的图像 1,3 Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement, Disconnect the cyclo converter: 步骤 4 中的图像 2,3 Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement, Disconnect the cyclo converter: 步骤 4 中的图像 3,3
    • Pull the cyclo converter panel off of its posts on the generator body so the screw terminals are easily accessible.
  5. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 5 中的图像 1,3 Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 5 中的图像 2,3 Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 5 中的图像 3,3
    • Disconnect the two 2-pin and one 3-pin connectors from the panel.
    • Take note of which connector corresponds with each header for reassembly.
    • Reassembly tip: The connectors are keyed so they can not be plugged in with the wrong orientation.
  6. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement, Disassembly tip: 步骤 6 中的图像 1,1
    • If you are replacing the cyclo converter panel, it can be helpful to transfer a cable from the old panel to the corresponding screw terminal on the replacement panel one at a time. This prevents potentially mixing up cables and screws and maintains OEM cable management.
    • The top three screws are M4 screws while the bottom four are M5 screws. Ensure you are using the correct screw for each terminal during reassembly.
  7. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the seven 10 mm screws from the terminals on the cyclo converter panel. The wire that corresponds with each terminal is listed below:
    • Red cable
    • Double Black cable
    • No cable
    • White Cable
    • Double Red cable
    • Double White cable
    • Double Blue cable
  8. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 8 中的图像 1,2 Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement: 步骤 8 中的图像 2,2
    • Remove the terminal connecting bar from the panel once the corresponding terminals are unscrewed.
    • During reassembly, ensure the bar is in the correct orientation and lies under the crimp connector on the double black cable.
  9. Honda 3000 Watt Generator EB3000CK2A Cyclo Converter Replacement, Remove the cyclo converter unit: 步骤 9 中的图像 1,1
    • Remove the cyclo converter unit.
结论
另外一个人完成了本指南。
Tarun Thiruma
于11/20/19注册
35,516 声望
创作了134篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 913
