跳转到主内容
Homelite UT44172 Operating Switch Replacement
你所需要的
  1. Homelite UT44172 Operating Switch Replacement, Opening Device: 步骤 1 中的图像 1,1
    • Use a Philips-head screwdriver to remove the six, 15 mm screws from the casing.
  2. Homelite UT44172 Operating Switch Replacement, Remove Faceplate: 步骤 2 中的图像 1,1
    • Remove the faceplate from the main body of the device, lift it and expose the inner mechanisms.
  3. Homelite UT44172 Operating Switch Replacement, Switch Removal: 步骤 3 中的图像 1,2 Homelite UT44172 Operating Switch Replacement, Switch Removal: 步骤 3 中的图像 2,2
    • Locate and remove the operating switch from the device.
  4. Homelite UT44172 Operating Switch Replacement, Spring Replacement: 步骤 4 中的图像 1,1
    • Replace the spring if it is deformed or broken.
    • Be careful that the wires do not get caught in the spring when replacing it.
结论
Adam soto
于01/30/15注册
301 声望
创作了3篇指南
团队
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G5
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 348
