跳转到主内容
Homelite UT44172 Blades Replacement
你所需要的
  1. Homelite UT44172 Blades Replacement, Removing Screws: 步骤 1 中的图像 1,1
    • Remove the six 15.0 mm screws from the body of the device with a Phillips #2 screwdriver.
  2. Homelite UT44172 Blades Replacement, Removing Faceplate: 步骤 2 中的图像 1,1
    • Remove the face plate by lifting it away from the other half of the device. This will expose the interior.
  3. Homelite UT44172 Blades Replacement, Exposing Blade Components: 步骤 3 中的图像 1,2 Homelite UT44172 Blades Replacement, Exposing Blade Components: 步骤 3 中的图像 2,2
    • Use the Phillips #2 screwdriver to remove the four 10.0 mm screws on the bottom of the blades.
  4. Homelite UT44172 Blades Replacement, Replacing Blades: 步骤 4 中的图像 1,3 Homelite UT44172 Blades Replacement, Replacing Blades: 步骤 4 中的图像 2,3 Homelite UT44172 Blades Replacement, Replacing Blades: 步骤 4 中的图像 3,3
    • Remove the old blades by pulling them away from the gears and motor.
    • Be careful handling the blades. They are sharp.
结论
Adam soto
于01/30/15注册
301 声望
创作了3篇指南
团队
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 的会员
USFT-WATKINS-W15S17G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 727
