跳转到主内容
HomePod 2023 woofer Replacement
你所需要的
    • flip your speaker onto its back.
    • using your scissors, carefully cut through the fabric just enough so you can remove it from the speaker's body.
    • using your spludger, pry out the 8 plastic plugs that are hiding the screws.
    • using your screwdriver, remove the 8 screws that are holding the speaker's body together.
    • using your spludger, carefully pry into the base.
    • be careful as to not damage the ribbon cable that is still attached to the motherboard.
    • using your screwdriver, remove the 6 screws that are holding the speaker in place.
    • using the spludger, carefully pry under the speaker to get it out.
    • be very careful when prying as there are wires that are connected to the motherboard.
    • when replacing the new woofer, apply the new seal.
    • carefully using 2 fingers, remove both of the connectors that connect to the speaker from the motherboard.
结论
另外一个人完成了本指南。
776831
于06/10/21注册
1,034 声望
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 30
总计 744
