跳转到主内容
Holmes HEH8031 Safety Weight Replacement
你所需要的
  1. Holmes HEH8031 Safety Weight Replacement, Housing: 步骤 1 中的图像 1,1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Safety Weight Replacement: 步骤 2 中的图像 1,1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Safety Weight Replacement: 步骤 3 中的图像 1,2 Holmes HEH8031 Safety Weight Replacement: 步骤 3 中的图像 2,2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Safety Weight Replacement, Circuit Board Removal: 步骤 4 中的图像 1,1
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Safety Weight Replacement, Safety Weight: 步骤 5 中的图像 1,2 Holmes HEH8031 Safety Weight Replacement, Safety Weight: 步骤 5 中的图像 2,2
    • Remove wires from safety weight, as shown.
    • Pull upward on the blue connectors.
    • If connectors are tough to remove, try wiggling while pulling upward.
  6. Holmes HEH8031 Safety Weight Replacement: 步骤 6 中的图像 1,1
    • Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
结论
Deanna Jack
于10/12/16注册
333 声望
创作了4篇指南
团队
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G1
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 537
