跳转到主内容
Holmes HEH8031 Power Cord Replacement
你所需要的
  1. Holmes HEH8031 Power Cord Replacement, Housing: 步骤 1 中的图像 1,1
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Power Cord Replacement: 步骤 2 中的图像 1,1
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Power Cord Replacement: 步骤 3 中的图像 1,2 Holmes HEH8031 Power Cord Replacement: 步骤 3 中的图像 2,2
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Power Cord Replacement, Power Cord: 步骤 4 中的图像 1,3 Holmes HEH8031 Power Cord Replacement, Power Cord: 步骤 4 中的图像 2,3 Holmes HEH8031 Power Cord Replacement, Power Cord: 步骤 4 中的图像 3,3
    • Decrimp the wire nuts from both wire connections.
    • Remove wire nuts to expose wire strands.
    • Separate all connected wires.
  5. Holmes HEH8031 Power Cord Replacement: 步骤 5 中的图像 1,3 Holmes HEH8031 Power Cord Replacement: 步骤 5 中的图像 2,3 Holmes HEH8031 Power Cord Replacement: 步骤 5 中的图像 3,3
    • Pull on the cord from the outside of the heater with great finesse. At the same time, push the cord clamp out of the housing from the inside.
    • Separate the two halves of the cord clamp and remove from cord.
  6. Holmes HEH8031 Power Cord Replacement: 步骤 6 中的图像 1,2 Holmes HEH8031 Power Cord Replacement: 步骤 6 中的图像 2,2
    • Prepare the replacement cord by cutting the negative branch (black) at least 8 inches shorter than the positive branch (white).
    • Strip at least 3/4 inch of insulation from the cord to expose bare wire.
    • Twist wire ends to form a tight braid.
结论
3等其他人完成本指南。
Deanna Jack
于10/12/16注册
333 声望
创作了4篇指南
团队
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G1
4 名成员
创作了16篇指南
一条评论
Are there substitute power cord for Holmes HEH8031 power cord replacement?
Terri Allen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 1,910
