本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this repair if you want to replace your fan blade assembly. Be sure to turn off the power and unplug the heater before beginning to change the fan assembly. The screws in this heater are recessed, so using a magnetic screwdriver will be helpful. Note: When reassembling the unit, you must replace the 2 machine screws that connect the rotor assembly to the housing before replacing the coarse-threaded screws. Aligning the machine screws may take some finesse.
你所需要的
Identify that you have the Holmes HEH8031 heater. The model number is on the bottom of the unit.
