跳转到主内容
加入维修社区 - 创建账户
Hollowtech Bottom Bracket Replacement
你所需要的
  1. Hollowtech Bottom Bracket Replacement, Bottom Bracket: 步骤 1 中的图像 1,1
    • Secure the bicycle using a bicycle repair stand or wall.
  2. Hollowtech Bottom Bracket Replacement: 步骤 2 中的图像 1,2 Hollowtech Bottom Bracket Replacement: 步骤 2 中的图像 2,2
    • Use pliers to remove the spring clip from the chain's master link clip.
    • Remove the master link plate, plate and pin assembly, and finally the chain.
  3. Hollowtech Bottom Bracket Replacement: 步骤 3 中的图像 1,3 Hollowtech Bottom Bracket Replacement: 步骤 3 中的图像 2,3 Hollowtech Bottom Bracket Replacement: 步骤 3 中的图像 3,3
    • Use a 10mm Allen key socket and ratchet to loosen the left crank arm by twisting counter clockwise.
    • Remove the left crank arm.
    • Remove the spacer(s) and washer.
  4. Hollowtech Bottom Bracket Replacement: 步骤 4 中的图像 1,3 Hollowtech Bottom Bracket Replacement: 步骤 4 中的图像 2,3 Hollowtech Bottom Bracket Replacement: 步骤 4 中的图像 3,3
    • Either push or pull the crank arm fully out exposing the left bottom bracket.
  5. Hollowtech Bottom Bracket Replacement: 步骤 5 中的图像 1,2 Hollowtech Bottom Bracket Replacement: 步骤 5 中的图像 2,2
    • Use Park Tool's BBT-27.3 16 notch bottom bracket tool to loosen the left bottom bracket by twisting counter clockwise.
    • Remove the bottom bracket.
  6. Hollowtech Bottom Bracket Replacement: 步骤 6 中的图像 1,2 Hollowtech Bottom Bracket Replacement: 步骤 6 中的图像 2,2
    • Use Park Tool's BBT-27.3 16 notch bottom bracket tool to loosen the right bottom bracket by twisting counter clockwise.
  7. Hollowtech Bottom Bracket Replacement: 步骤 7 中的图像 1,3 Hollowtech Bottom Bracket Replacement: 步骤 7 中的图像 2,3 Hollowtech Bottom Bracket Replacement: 步骤 7 中的图像 3,3
    • Carefully pull out the bottom bracket shell.
结论
Congratulations, you have completed the guide. To reassemble the crankset, follow these instructions in reverse order. Make sure to grease the threads, bottom bracket shell, and crankset accordingly. In addition, torque down the crank arm (38-41Nm) and bottom bracket (40-50Nm) to the manufacturer's recommended specification.
Agustin Sernas
于10/23/23注册
145 声望
撰写一个指南
团队
CSU Los Angeles, Team 13-3, Ribeiro Fall 2023 CSU Los Angeles, Team 13-3, Ribeiro Fall 2023 的会员
CSULA-RIBEIRO-F23S13G3
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 48
总计 684
