跳转到主内容
Holley 4 Barrel Carburetor Gasket Replacement
你所需要的
  1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: 步骤 1 中的图像 1,3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: 步骤 1 中的图像 2,3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: 步骤 1 中的图像 3,3
    • Make sure your carburetor has no fuel inside.
  2. Holley 4 Barrel Carburetor Gasket Replacement: 步骤 2 中的图像 1,1
    • Remove the four 47 mm flat head screws.
  3. Holley 4 Barrel Carburetor Gasket Replacement: 步骤 3 中的图像 1,1
    • Remove the bowl from the side of the carburetor.
  4. Holley 4 Barrel Carburetor Gasket Replacement: 步骤 4 中的图像 1,1
    • Remove the four 63 mm flat head screws.
  5. Holley 4 Barrel Carburetor Gasket Replacement: 步骤 5 中的图像 1,1
    • Remove the bowl and the steel fuel line from the side of the carburetor.
  6. Holley 4 Barrel Carburetor Gasket Replacement: 步骤 6 中的图像 1,2 Holley 4 Barrel Carburetor Gasket Replacement: 步骤 6 中的图像 2,2
    • Remove the spacer from the side of the carburetor.
    • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
  7. Holley 4 Barrel Carburetor Gasket Replacement: 步骤 7 中的图像 1,1
    • Remove the six 2.5 mm hex screws from the secondary metering block.
    • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
  8. Holley 4 Barrel Carburetor Gasket Replacement: 步骤 8 中的图像 1,1
    • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
  9. Holley 4 Barrel Carburetor Gasket Replacement: 步骤 9 中的图像 1,2 Holley 4 Barrel Carburetor Gasket Replacement: 步骤 9 中的图像 2,2
    • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
    • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 43
总计 4,491
