跳转到主内容
How you put your iPhone 7 into DFU Mode?
    • Connect your iPhone 7 to a computer or laptop with the lightning to USB cable.
    • Push and hold the sleep/wake button and the volume down button (the – button) at the same time, and do this for exactly 10 seconds.
    • After the 10 seconds, release the sleep/wake button, but continue to hold the volume down button for another 10 seconds. Pay attention! Unlike recovery mode where you get to see the message ‘Connected to iTunes’, the screen will remain black in DFU mode.
    • If you do see the connected to iTunes message, this means going to DFU mode has failed, and you have to start over from step 1.
    • Turn on iTunes. You should get a message stating: ‘iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes’.
    • The next step is to get your iPhone 7 out of DFU mode. As long as your iPhone works fine, this should not be a problem. The only thing you have to do is:
    • Push the sleep/wake button and the volume down button at the same time until the Apple logo appears. Your iPhone should automatically go to the lock screen.
结论
Have you tried everything, but your iPhone 7 still doesn’t work properly? Then, it is likely not a software problem, which means a repair is the only solution.
5等其他人完成本指南。
由衷感谢以下译者:
nl en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Brian van Leeuwen
于10/27/16注册
229 声望
撰写一个指南
一条评论
What can I do in DFU mode?
Aspect22 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 48
过去 30 天: 255
总计 6,464
