跳转到主内容
Hockey Glove Palm Repair
你所需要的
  1. Hockey Glove Palm Repair, Hockey Glove Palm Repair: 步骤 1 中的图像 1,1
    • Using measuring tape, measure the dimensions of the hole to approximate how much material is needed.
  2. Hockey Glove Palm Repair: 步骤 2 中的图像 1,2 Hockey Glove Palm Repair: 步骤 2 中的图像 2,2
    • Using the dimensions gathered from the previous step, cut the fabric to size leaving some excess material.
    • You can use fabric from other gloves that are still intact to repair the glove in need.
  3. Hockey Glove Palm Repair: 步骤 3 中的图像 1,1
    • Draw an approximate shape of the hole on the fabric as a guide for stitching using a marking tool that will show up on fabric.
  4. Hockey Glove Palm Repair: 步骤 4 中的图像 1,2 Hockey Glove Palm Repair: 步骤 4 中的图像 2,2
    • Thread a needle with enough thread for the size of the hole you are repairing.
    • A sewing machine can be used instead of hand sewing if you would prefer.
  5. Hockey Glove Palm Repair: 步骤 5 中的图像 1,2 Hockey Glove Palm Repair: 步骤 5 中的图像 2,2
    • Apply the adhesive to the perimeter of the hole.
  6. Hockey Glove Palm Repair: 步骤 6 中的图像 1,1
    • Position the material on the glove to completely cover the hole leaving a bit of overlap.
    • Allow the adhesive time to dry so that the material is firmly stuck to the glove.
  7. Hockey Glove Palm Repair: 步骤 7 中的图像 1,2 Hockey Glove Palm Repair: 步骤 7 中的图像 2,2
    • Reinforce replacement material to the palm through hand stitching.
    • To hand stitch, push the needle through the front of the fabric and pull the thread through. Do the same from the inside of the glove. Continue to weave in and out creating stitches that are as close together as possible.
  8. Hockey Glove Palm Repair: 步骤 8 中的图像 1,1
    • Trim excess the material from around the area of replacement
结论
Dora D'Accardo
于04/19/23注册
157 声望
撰写一个指南
团队
UC Davis, Team 1-6, Morris Spring 2023 UC Davis, Team 1-6, Morris Spring 2023 的会员
UCD-MORRIS-S23S1G6
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 68
总计 2,032
