简介
You may have a broken or bent door hinge if the refrigerator door does not close tightly. The door hinge bends when there is too much weight stored on the door shelves. If the refrigerator is not balanced then the door hinge may bend or break. This guide shows you how to replace a broken door hinge.
你所需要的
视频概述
Remove all the food and containers from the shelves on the refrigerator door.
Remove the plastic cover with a plastic tool to avoid breaking or damaging the cover.
Pry open the cover at the arrow indicated on the cover.
Remove the three 10 mm hex nuts.
Use a socket wrench to loosen the nuts. Set the nuts aside in a safe place.
Remove the mounting bracket.
Open the door 90 degrees. Lift the door up and off the refrigerator.
Use a Phillips #2 screwdriver to remove the screw from the metal bracket on the bottom of the door. Lift the metal bracket off the plastic mount.
Grab the broken door hinge by the side and pull it from the hole.
Insert the new hinge and tighten the screw.
Hold the door facing 90 degrees from the refrigerator.
Use an index finger to get the position of the hole on the door to be placed onto the bracket hinge of the refrigerator.
Set the door onto the mounting bracket.
Make sure that the door is level with the opposite door.
Make sure that the magnetic strip is at the same depth you measured in step 2.
Place the top bracket over the bolts. Tighten the three 10 mm nuts to hold the bracket in place.
Replace the bracket cover and snap it back into place.
6条评论
Can you tell me where can I buy the replacement part?
There is a Hitachi factory near my house.
Thanks for your reply ,Can you help me to buy the part for L and R side door after the perintah kawalan pergerakan ,i cannot find at Melaka so bad. You tell how much the cost i will bank in for you. your help i will appreciate
Hello Mr. Seng can you please arrange this part for hinge replacement. As I can't find it anywhere in the world.
I will send the money in advance
Hello how are you
I want to buy this left and right part
Hi
Those who needed the parts can possible contact the below
Arçelik Hitachi Home Appliances Sales Malaysia Sdn. Bhd.
(Formerly known as Hitachi Sales (Malaysia) Sdn. Berhad)
[Registration no: 197101001183(11543-V)]
Lot 12, Jalan Kemajuan, Bangi Industrial Estate
43650 Bandar Baru Bangi
Selangor Darul Ehsan
Tel : 03-89112600
Fax : 03-89263013
Email :marketing.AHMY@arcelik-hitachi.com (General Info)services.AHMY@arcelik-hitachi.com (Service & Repair)sparepart.AHMY@arcelik-hitachi.com (Spare Part)
