跳转到主内容
加入维修社区 - 创建账户
Hitachi CP-X440 Sensor Replacement
你所需要的
  1. Hitachi CP-X440 Sensor Replacement, Sensor: 步骤 1 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the six 2 cm screws from the bottom of the case.
    询问修复机器人
    添加评论
  2. Hitachi CP-X440 Sensor Replacement: 步骤 2 中的图像 1,2 Hitachi CP-X440 Sensor Replacement: 步骤 2 中的图像 2,2
    • Flip the projector back upright and place the back of projector towards you. Unscrew the 3 screws circled in the back with your Phillips #1 Screwdriver. Each screw is 1 cm in length.
    • Then unscrew the two silver, 1 cm screws on the light switch panel with a Phillips #1 Screwdriver
    询问修复机器人
    添加评论
  3. Hitachi CP-X440 Sensor Replacement: 步骤 3 中的图像 1,3 Hitachi CP-X440 Sensor Replacement: 步骤 3 中的图像 2,3 Hitachi CP-X440 Sensor Replacement: 步骤 3 中的图像 3,3
    • You will now be able to pop the top of the projector off.
    • To uncollapse the projector top fully from the projector, you can pull the black cord from the white holder near the lens, circled in red and orange.
    • With front of projector now facing you, the sensor can be found on the left of the lens.
    询问修复机器人
    添加评论
  4. Hitachi CP-X440 Sensor Replacement: 步骤 4 中的图像 1,2 Hitachi CP-X440 Sensor Replacement: 步骤 4 中的图像 2,2
    • The sensor will be held into the projector by a silver screw on the lower left side of lens. This single 2 mm screw will need to be unscrewed and removed. This will allow you to remove the sensor piece completely out of the projector.
    • You now will remove the sensor piece completely.
    询问修复机器人
    添加评论
  5. Hitachi CP-X440 Sensor Replacement: 步骤 5 中的图像 1,3 Hitachi CP-X440 Sensor Replacement: 步骤 5 中的图像 2,3 Hitachi CP-X440 Sensor Replacement: 步骤 5 中的图像 3,3
    • To get the sensor piece alone, you will unscrew the single 3 mm silver screw.
    • Once this screw in the sensor piece is removed, the sensor piece will be alone and can be replaced with your new one.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 371
