简介
After extended use, the charging port may be worn down. If the device will not power on after charging, the charging port may be defective.
你所需要的
Remove the back cover of the device using a combination of both plastic opening tools.
Use your plastic opening tool pry open a corner of the device, then continue down the side of the device with the tool to completely open the device.
即将完成!
结论
2等其他人完成本指南。
