跳转到主内容
Hisense Sero 7 Pro Speakers Replacement
你所需要的
  1. Hisense Sero 7 Pro Speakers Replacement, Battery: 步骤 1 中的图像 1,2 Hisense Sero 7 Pro Speakers Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Speakers Replacement: 步骤 2 中的图像 1,2 Hisense Sero 7 Pro Speakers Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to disconnect the battery from the motherboard.
  3. Hisense Sero 7 Pro Speakers Replacement: 步骤 3 中的图像 1,2 Hisense Sero 7 Pro Speakers Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, carefully place under one corner of the battery.
    • Move around edges of the battery to lift it off of the tablet.
    • Remove battery from tablet.
  4. Hisense Sero 7 Pro Speakers Replacement, Speakers: 步骤 4 中的图像 1,3 Hisense Sero 7 Pro Speakers Replacement, Speakers: 步骤 4 中的图像 2,3 Hisense Sero 7 Pro Speakers Replacement, Speakers: 步骤 4 中的图像 3,3
    • Peel back the film holding the speaker wire in place
    • Detach both wire connectors
  5. Hisense Sero 7 Pro Speakers Replacement: 步骤 5 中的图像 1,1
    • Using a plastic opening tool, carefully place under one corner of each speaker
    • Remove both speakers
结论
Logan Phillips
于05/09/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S4-G1, Harley Spring 2017 IUPUI, Team S4-G1, Harley Spring 2017 的会员
IUPUI-HARLEY-S17S4G1
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 145
