跳转到主内容
Hisense Sero 7 Pro Rear Camera Replacement
你所需要的
  1. Hisense Sero 7 Pro Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 1,2 Hisense Sero 7 Pro Rear Camera Replacement, Rear Camera: 步骤 1 中的图像 2,2
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Rear Camera Replacement: 步骤 2 中的图像 1,1
    • Using a metal or nylon spudger, begin to peel the tape from the motherboard that it is attached to the camera.
    • If needed, the same steps can be applied to front camera.
  3. Hisense Sero 7 Pro Rear Camera Replacement: 步骤 3 中的图像 1,3 Hisense Sero 7 Pro Rear Camera Replacement: 步骤 3 中的图像 2,3 Hisense Sero 7 Pro Rear Camera Replacement: 步骤 3 中的图像 3,3
    • Pull the camera toward you to detach from the tablet.
    • Use caution when detaching camera from port.
结论
Baochau Nguyen
于10/11/16注册
314 声望
创作了3篇指南
团队
Texas Tech, Team 38-2, Bennett Fall 2016 Texas Tech, Team 38-2, Bennett Fall 2016 的会员
TTU-BENNETT-F16S38G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 218
