跳转到主内容
Hisense Sero 7 Pro GPS Antenna Replacement
你所需要的
  1. Hisense Sero 7 Pro  GPS Antenna Replacement, GPS Antenna: 步骤 1 中的图像 1,2 Hisense Sero 7 Pro  GPS Antenna Replacement, GPS Antenna: 步骤 1 中的图像 2,2
    • Turn tablet off before disassembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro  GPS Antenna Replacement: 步骤 2 中的图像 1,2 Hisense Sero 7 Pro  GPS Antenna Replacement: 步骤 2 中的图像 2,2
    • Pull the Wi-Fi antenna directly upwards to remove it from the motherboard.
    • Be gentle when disconnecting the antenna because it may damage the part it is attached to.
  3. Hisense Sero 7 Pro  GPS Antenna Replacement: 步骤 3 中的图像 1,2 Hisense Sero 7 Pro  GPS Antenna Replacement: 步骤 3 中的图像 2,2
    • Insert a metal or nylon spudger on the edge of the GPS satellite and begin separating it from the adhesive.
    • Slowly peel the GPS from left to right as the GPS is clammy.
结论
Baochau Nguyen
于10/11/16注册
314 声望
创作了3篇指南
团队
Texas Tech, Team 38-2, Bennett Fall 2016 Texas Tech, Team 38-2, Bennett Fall 2016 的会员
TTU-BENNETT-F16S38G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 272
