跳转到主内容
Hipstreet Titan Plus Motherboard Replacement
你所需要的
  1. Hipstreet Titan Plus Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,2 Hipstreet Titan Plus Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Use the plastic opening tools to pry the screen from the back of the device.
  2. Hipstreet Titan Plus Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the spudger to remove the speaker from the back casing of the device.
  3. Hipstreet Titan Plus Motherboard Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the black adhesive strips from the wires using the tweezers, and set the strips aside.
  4. Hipstreet Titan Plus Motherboard Replacement: 步骤 4 中的图像 1,2 Hipstreet Titan Plus Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the spudger to release three (3) black clips connecting the components to the motherboard.
  5. Hipstreet Titan Plus Motherboard Replacement: 步骤 5 中的图像 1,2 Hipstreet Titan Plus Motherboard Replacement: 步骤 5 中的图像 2,2
    • Unscrew the motherboard using a J0 Phillips head screwdriver.
  6. Hipstreet Titan Plus Motherboard Replacement: 步骤 6 中的图像 1,2 Hipstreet Titan Plus Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use the metal spatula to remove the battery from the back of the screen.
  7. Hipstreet Titan Plus Motherboard Replacement: 步骤 7 中的图像 1,2 Hipstreet Titan Plus Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use the soldering iron to heat the end of the wires connecting the speaker to the motherboard.
    • Apply heat until the wires are free.
  8. Hipstreet Titan Plus Motherboard Replacement: 步骤 8 中的图像 1,2 Hipstreet Titan Plus Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using the soldering iron, apply heat to the end of the wires until they are free from the motherboard.
  9. Hipstreet Titan Plus Motherboard Replacement: 步骤 9 中的图像 1,2 Hipstreet Titan Plus Motherboard Replacement: 步骤 9 中的图像 2,2
    • Now that the battery and speaker are removed, the black clips are undone, and the motherboard is unscrewed, remove the motherboard.
结论
另外一个人完成了本指南。
Kari Cannon
于10/30/15注册
500 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-1, Miles Fall 2015 UMass Dartmouth, Team 1-1, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 367
