跳转到主内容
Hipstreet Titan 2 HD Battery Replacement
你所需要的
  1. Hipstreet Titan 2 HD Battery Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Battery Replacement: 步骤 2 中的图像 1,1
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Battery Replacement: 步骤 3 中的图像 1,1
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Battery Replacement: 步骤 4 中的图像 1,2 Hipstreet Titan 2 HD Battery Replacement: 步骤 4 中的图像 2,2
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Battery Replacement: 步骤 5 中的图像 1,2 Hipstreet Titan 2 HD Battery Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Battery Replacement: 步骤 6 中的图像 1,1
    • Once the speaker is disconnected, the cover removal is complete.
  7. Hipstreet Titan 2 HD Battery Replacement, Battery: 步骤 7 中的图像 1,2 Hipstreet Titan 2 HD Battery Replacement, Battery: 步骤 7 中的图像 2,2
    • Remove the black placement tape from the battery.
    • Find the two battery solder connections on the circuit board.
  8. Hipstreet Titan 2 HD Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the red and black battery wires from the circuit board with the solder removal tool.
  9. Hipstreet Titan 2 HD Battery Replacement: 步骤 9 中的图像 1,1
    • Solder the new battery wire connectors to the circuit board.
    • The battery wires must be installed with the red wire on the left and black wire on the right.
结论
另外一个人完成了本指南。
Jeffrey
于03/11/15注册
766 声望
创作了5篇指南
团队
Colorado Springs, Team 5-6, Panko Spring 2015 Colorado Springs, Team 5-6, Panko Spring 2015 的会员
UCCS-PANKO-S15S5G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 9
总计 4,278
