跳转到主内容
Hipstreet Equinox 2 Battery Replacement
你所需要的
  1. Hipstreet Equinox 2 Battery Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Battery Replacement: 步骤 2 中的图像 1,1
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Disconnect the wires that connect the battery to the motherboard using the spudger.
  4. Hipstreet Equinox 2 Battery Replacement: 步骤 4 中的图像 1,1
    • Slide the spudger underneath the battery and gently lift it off of the adhesive.
  5. Hipstreet Equinox 2 Battery Replacement: 步骤 5 中的图像 1,2 Hipstreet Equinox 2 Battery Replacement: 步骤 5 中的图像 2,2
    • Place the new battery in the same location and connect the wires the same way as the previous battery.
结论
团队
Clemson, Team 15-8, Shirley Winter 2015 Clemson, Team 15-8, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S15G8
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 763
