跳转到主内容
Heyday Wireless Bluetooth Speaker 9979 Battery Replacement
你所需要的
  1. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement, Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 1 中的图像 1,1
    • Remove the four bezels from the speaker's back cover.
    • Try to get under the bezel by using force, and pull it out little by little.
  2. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the four 1.6 mm screws. Rotate the driver counterclockwise to remove the screws.
  3. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 3 中的图像 1,2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the cover of the wireless speaker using the metal spudger. Don't use much force to remove it.
  4. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 4 中的图像 1,2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 4 中的图像 2,2
    • Once you have pulled the cover to the side, remove the two screws with a Philips #000 screwdriver. Turn counterclockwise.
  5. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 5 中的图像 1,2 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 5 中的图像 2,2
    • The battery might be glued down so use the black nylon spundger to take it out completely.
  6. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 6 中的图像 1,3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 6 中的图像 2,3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using the nylon tipped tweezers, remove the motherboard carefully. It is recommended to grab the motherboard in the middle as there are no big buttons on it.
  7. Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 7 中的图像 1,3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 7 中的图像 2,3 Heyday Wireless Bluetooth Speaker 9979 Battery Replacement: 步骤 7 中的图像 3,3
    • You want to remove the white power cable connector from the motherboard. Start by using the fixit opening pick to pull it up. Once it is almost out, use you're fingers to just simply disconnect it.
结论
Thanh Duong
于09/26/22注册
195 声望
撰写一个指南
团队
CSU Los Angeles, Team 5-4, Adachi Fall 2022 CSU Los Angeles, Team 5-4, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G4
5 名成员
创作了2篇指南
4条评论
The grammar could be improved by simplifying the steps (not using too many words or try separating into multiple bullet points) and avoiding the use of ambiguous pronouns (it).
Jadealyn Paulino - 回复
Will do, thanks!
Chris Yepez -
There are a lot of images and some are the same.
Cindy Munoz - 回复
The description of each tool needed was a very useful touch.
Cindy Munoz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 531
